BonzoRosso
Good evening,
I would like to solve the following problem.
premise: I have a 3d model of a supplier with and already frozen pdm mounts, so they are blocked. I have no possibility to change the 3d, on all models there are positioning errors and geometry.
I'd like to round the odds, but I've seen that I can only give the number of decimals. for example if a support is placed at 115.36 mm I would like it to be rounded at +/- 0.5 and then at 115.5 and not at 115.3 setting as decimal values the value 1
I would not want to force the quota, since, if edited manually this does not update if in the future they will change the piece, which is very likely. and I should go check one by one quota to check if the value is correct.
