change shape without distortion
  • Thread starter Thread starter carlag001
carlag001
Hello everyone
I am neophyte of rhino and I apologize for ignorance...
I would like to understand if I can create a form like the one I attach: It is a kind of empty ring (tube) that should not be deformed in its measurements but must take the form, as if the ring had been crushed.
I tried with "change with cage", but with bad results.
thanks to who will give me a suggestion! carlag
I used rhino years ago. Sounds like version 4
I think there was a possibility of loft command
you must describe the two profiles (green and red) on two floors apart from each other.
and then join the two profiles with the loft command
Thank you very much
the line is difficult to define, I hoped to succeed in getting it with deformation:unsure:: In case I make a precise model and I'm going to point out some points to pass the lines to join. Thank you!
