change share with double click
  • Thread starter Thread starter Atreiou
Atreiou
I am used to modify the odds with a double click on the same, both in sketch and in part that together, pop-up appears, edit, green tick and is done.
Now from a while not always this happens, and occasionally I am obliged to change the share in the property manager and the pop up does not appear.
Did I change any arrangements without realizing what I was going to do?
not exactly, the pop-up that does not always come out is what I allego
Instant2d is currently disabled
you have to bring back the situation to one or more common elements. otherwise as you do to understand what could be the solution.
When it happens, you do a quick examination of the situation and the process you have done (hope: are you together? Are you changing part together? is it a configured part? Are there equations? )
I also found this antipathic problem with sw2017. I couldn't tie him to some particular event. when it happens and if you want to change the share you have to do it in the property manager.
ps: I haven't heard the assistance since I don't want to reinstall everything! :
tonight I tried sketching, part, together, and total together
It always works.
Sometimes it just doesn't... eccheccazz..
It happened exactly to me a couple of times (sw 2017 sp5) , in the end I threw the sponge and in one case I did the sketch from 0 in the other I forced the property man. I think it's a bug..
even to me it happened but with the sp1 then with the successive it disappeared....boh perhaps it is due to some update of windows
probably depends even if you work on components created by previous versions... but it is definitely a bug
