change symbols welding module
  • Thread starter Thread starter ita71
ita71
Hello everyone
I managed to actuate using pro-e wf 4.0 and are struggling with the welding module, no problem for the use of the module, the problem arises with the parametric symbols of the same in drw environment, attached place an example and as you see it is set wrong, too decimal on the values and in some cases the length value of the cord overlaps to the symbol of type of soldering, I tried to redefine the symbols English
hi the symbol find it in:
....\program files\ptc\creo 2.0\common files\m110\symbols\library_syms\weldsymlib\iso_weld\ or\ansi_weld\
Good luck because they are parametric symbols and are a nice mess to change... .
