mali_fx Guest Nov 26, 2009 #1 I would like to change the background of the single table without changing that of the 3d, is it possible?
lollone Guest Nov 26, 2009 #2 You can do it. everything depends on the syscol.scl file that is loaded at pro-e startup. view/display settings/color system you have to adjust the color "background". once chosen save by name. in the config you must set the file to upload. system_colors_file c:\...
