change the link of a drawing on catia v5
  • Thread starter Thread starter Marco Zaramella
Marco Zaramella
example of the problem.
in a assembly I have 2 parts on one of the 2 parts (choice part1) I make the table, which of course will be linked to it (chosing as reference the xy plan).
question:
is it possible to change the link to the drawing to make it point to the part2, better still to the assembly?
I tried with objects "front view/change links" or "applies links to", but I couldn't.
Mar
hi also I use catia v5,
to do as you say I go to edit and click links,
at that point I enter in a window that opens my product or part files
of catia. type that on the file I have to point to, click on open
and finally on ok of the window where I change the links.
then I give the update command.
test
and good work
Hello, Renato, I tried too, but it makes me mistake.
Hello, I'm reborn.
I'm sorry I didn't help you and I didn't answer you immediately; you then managed
I'm trying to fix this? If you can let me know how? You never know.
instead I have a problem on the quota lines, how do I keep the extension lines always to zero without each time going to set them on the properties?
Can you give me some advice? Thank you.
hi ferrezio, I do not use "save as a new document" among other things is a command I do not know.
As far as you're reborn, I can't give you an answer, even I've clashed with those 2 mm default that leaves you the quota, I've desisted. . .
the error message depends on the fact that you are trying to link the design to a part/product with different uuid (see discussions on this). This is not possible.
hi robcrac, I visited the discussion on uuid, now it is clearer to me, but I remain a question.
I can create a "save with name" part, I keep the same uuid. so I can replace the 2 parts when I want it, but can I point the link on an assembly? As the assembly environment is different I think you release a uuid different from the part.
I hope you understand... I read this text in a few days I'd be struggling.
that I know is not possible, precisely because a part and a assembly are different files and therefore have different uuid.
Good evening to all,
I put myself in this discussion not to open a new... .
in a catdrawing file pointing to a complex catproduct, with the command edit links,
the system indicates that the catdrawing has 2 pointed documents:
the correct catproduct,
and another catproduct (not correct that I want to delete) the type of unsolicited link is a billofmaterial that the system does not let me cut/delete.
thanks for the help
Sbilf
Hello, I'm reborn.
you must change the standards :smile:
