change the scale of a part!
  • Thread starter Thread starter Jonhson91
Jonhson91
I finished making a total, and I agreed now that the scale of the pieces was 2:1, instead of 1:1
I find myself therefore with all the details, already assembled, in double dimensions of the real ones. Now, I know there's a way to change the scale of every detail, piece by piece, but I can't find it, how do you do it?
Is there any way not to lose my assembly already assembled, or do I have to change the scale piece by piece and then reassemble everything from top?
thanks to those who will answer:smile:
you have to open ogn isoingolo component in partdesign environment and then use the scale function.
as a reference I recommend you select the 0.0.0 point that is found in the main axis. If this is present, otherwise you create a new one.
Thanks for the answer! Can I ask you how to get this function? because I was an hour looking for all the commands, but I really can't find it!
