cacciatorino
for a job, I have to make an offset of a plastic printed piece (we have to make a patchwork with the cnc). This printed piece has a lot of holes, which I've sat down with surfaces created on the spot, and so far everything's fine.
When I go to create the offset, it happens that the offset is on the right side for all surfaces, except one, which is copied from the opposite side. clearly in these conditions I can not then create the solid to use as a punch to make the carrier.
I think it's a problem of defining the direction of the normal surface, but I can't find a way to change it.
use swx 2012 standard.
