change type in creation wizard holes
  • Thread starter Thread starter pierluigip
pierluigip
Good morning to all
in one part I made 4 screw holes m5 with creation wizard holes
I need to change only one in m6 always within the same function
Is the only solution to erase the point and make it a new hole creation?
The hole is coupled in a set, I have to do it again?
use sw 2011 sp4.0
Good morning to all
use sw 2011 sp4.0
I think you have to do it in another function... At least I know something like that you can't do.
even that I know it is possible with creation wizard holes do something similar.
then you have to do two functions creation guided hole
the alternative is to use the cut function and draw 4 circles of which 3 equal e.g. ø=6mm and 1 e.g. 7mm according to your needs.
If you use the tag function, however, you can't take advantage of the drilling wizard in repeats for example. . .
