change unit measurement
  • Thread starter Thread starter Cosmea
Cosmea
good morning to all, are at the first experience with the use of creo (and in general with the design in 3d).
I realized I accidentally drew some pieces with the English measuring system :36_1_4:
is it possible to convert all the quotas imposed in the international system without having to draw everything again? or scale them somehow?
thank you all!! !
... it is possible to convert all the quotas imposed in the international system without having to draw again...
Of course, to switch from inches to mm do so:
open details, then file > properties > unit > change
choose mm kg sec and select option 1 inch = 1 mm, otherwise multiply your odds by 25.4
These instructions are good for wf5, I don't know if with creo can change something.
then create strat part with the right values, so avoid that it will resurrect you.
p.s. as new entry in our forum I give you a warm welcome and invite you to present yourself in the special space:
http://www.cad3d.it/forum1/threads/463-presentazione-nuovi-utenti
