che hardware usare per top solid
  • Thread starter Thread starter SolProget
SolProget
I attach the configuration of the machine that I intend to buy for intensive use with topsolid/mold v6.10.
cpu intel core i7-2600k
ram ddr3 l 1600mhz 16gb (4x4gb)
geforce gtx 570 hd 2560mb
my greatest doubts are
1-Is it worth spending on xeon or is it okay also i7?
Does 2-topsolid still not handle multicore???
Does the graphics card look good for the geforce or the painting4000 improve me a lot of performance (it is worth it since it costs double)??
Thank you all for your interest.
hi the processor i7 is enough, the multicore with the mold will be used with the version 7 of topsolid in the 6 the multicore is exploited only in the cam environment with the cycles 3d, 4 axes and 5 axes continuous.
for the graphics card, it depends, if the mold assemblies are big you will want a picture.
for the processor I imagine you will take a 64 bit.
The ram is fine.
Thank you for your advice.
Since you mentioned the Moldovan module of version 7, I wanted to know if it's already there or if it's yet to go out because on topsolid site 7 I don't see demo or info about it.
At the moment there is a test version only for us that we are trying, you will have to wait next year for the Moldova.
The ram is fine.
I connect to this post because I also have a question about the video sheda mentioned (geforce gtx 570 hd). I should install solidworks 2012, okay this card? because on the site solidworks.it does not give me between the compatible...:confused: can I have problems of compatibility?
precise that I use solidworks not for hard/intensive use, I manage single pieces and small equipment for my workshop.
Hello excuse me if I only laugh at you today but I was a little messed up in this period, how configuration goes well
Thank you so much! I proceed with this configuration, at the worst I change only the card and I take a picture 2000...:rolleyes:
is the same configuration that I have and topsolid 2013 turns well. Of course if you manage very heavy assemblies a 2000 picture will certainly not hurt him. everything depends on your badge:)
I suggest you install a painting directly if you plan to move to top 7.
Solve some graphical visualization defects with transparent solids.
pe the computing power no problem!
Thursday
ps: stefano I don't want it!
Staff online
