check block selection
  • Thread starter Thread starter Principiante87
Principiante87
Good morning to all,
I am carrying out a specialist thesis for which vba programming is required with autocad 2011. My current problem is to start a macro, verify that there is a selected block, extract its name and perform other operations that I have already implemented. I have a lot of difficulty on the first part.. Can any of you help me? Thank you to anyone who wants to answer, and apologize for the question, I know that for many of you it will be trivial, but I can't solve this problem.. .
ciao, per la selezione puoi usare:
sub seleziona_blocco()
dim ssetmia as acadselectionset
dim filtertype(0) as integer
dim filterdata(0) as variant
filtertype(0) = 0
filterdata(0) = "insert"
'filtertype(1) = 2
'filterdata(1) = inserire il nome del blocco
if not isnull(thisdrawing.selectionsets.item("miaselezione")) then
thisdrawing.selectionsets.item("miaselezione").delete
end if
set ssetmia = thisdrawing.selectionsets.add("miaselezione")
ssetmia.selectonscreen filtertype, filterdata
if ssetmia.count > 0 then
msgbox "hai selezionato " & ssetmia.count & " blocchi.", vbinformation
else
msgbox "non hai selezionato nessun blocco.", vbexclamation
end if
set ssetmia = nothing
end sub
richiami vba con alt+ [F11]Enter the code
run the macro
(as in office)
if you already have the block name to select remove comments at
'filtertype(1) = 2
'filterdata(1) = Enter the block name
Enter the block name you want to select and put:
dim filtertype(1) as integer
dim filterdata(1) as variant
in the definitions of variables.
where there are msgboxes put the codes of what you want to do.
to you the management of errors and embellishments. . .
bye.
