check- mate
acarlett
Hello everyone,
how do you set a repair associated with a check-mate test in nx7.5?
in particular the test that imposed sasig-pdq>curve> small silhouette and curve. I would like to set a repair that combines the small segments found at the adjacent curve.
Thank you very much for your help.
you have to develop a custom with nx/open... because after that check you should apply to the curve (whose tag will be given by check) a join operation.
Here in these cases it seems to me that you use just another software. :smile:
it would not be bad to know what you are talking about (for pure curiosity)
For example, what is needed and what is a check mate and how a custom develops, but I realize that it could be arguments that would take too long for a brief description. . and time is the goods that scarceest to this world...
check mate is a tool to perform controls on nx parts.
There are hundreds of default controls that can be launched without doing anything.
you can also have a set of default check profiles. . .
where there are no defined checkpoints you can develop custom.
check define a "flag" that you lifted certify that your part follows your drawing rules.
how to develop a custom... :cool: armed with vb.net and go...
Thanks for the answer.
how can I assign in nx/open input the list of small segments found by check-mate?
each entity is tagged... You have to switch to the program that you write those tags that identify geometry.
