chi usa la v6?
  • Thread starter Thread starter stef_design
v5 is the other cad present where I worked, so the main interface I saw it and comparing myself to other colleagues, it had emerged precisely this first difference in the management of constraints.
I take my experience about v5 and v6 in the same company, if I needed a component of the v5 not yet imported, I then found myself dealing with an imported math like any other cad, very frustrating as what, that was a disrespect or choice of the cad manager I don't know, of course this made me miss a lot of time.
It's not like this anymore. v5 files are uploaded as native. Maybe you tried a v6 a while ago.
version r2013x the latest update.
Right.
did you really use v6 for 2 years? caspita, here abroad still do not use it in production. where I am now starting the first projects. We should all go to v6.
Are you so forward in Italy?
but, sorry, what command did you open v5 files on v6?
How did you find yourself with file search?
talk about workspace... how did you organize files?
What did you find incomplete?
Right.
the files I opened them through classical research, then right click and opened in catia, the double click with the left opened the enovia explorer to see the object (I hope it was a setting, but the graphics quality was very low).
search for files was not problematic, because it was set with many parameters including the business unit and as the codes had root according to the business unit, it was not difficult to find what you were looking for, different discourse for the uncoded files where to go with the search with the wildcard characters becomes a problem, but there was a more organizational problem of the various technical offices that in central office had not yet resolved.
enovia as it was set did not have workspace, there was only the local cache, this allowed to carry out more projects with multiple different teams (I saw that I was pre-industrialization, organization of the distinct and verification of the more complex 3ds) was very useful.
of incomplete compared to other cad "non catia" you mean?
No. between the v6 caia commands you used. In 2 years you have made a surface, an extrusion or not?
v6, however, arrived at 2016x. just so you know, huh?
and, at least since 2013, opens v5 files as they were native. In fact, since 2014, there is also compatibility to v5. so v5 can open v6. :cool:
Isn't that you're confused with the 3d experience?
because also on the site 3ds the v6 is still to the 2013x as last release:http://www.3ds.com/products-services/catia/products/v6/latest-release/I repeat, I don't know if it was a decided upstream setting from the cad manager, but every time we needed a v5 math, there came an import as if it came from another cad that didn't hit anything with the caty family.
as first thing I think is missing, it is a better management on repeat commands especially on series, where between part and product there is no direct link (if I insert a screw in a hole that is part of a series, I have to go tell him to the system that follows that certain series and even worse in some cases it is forced to create a set of points in shape in a product to follow the components a certain dislocation.
then there is a repeat command of a component already assembled, or assemble it from the beginning telling him how many components I need and put them one by one, or put one at a time as if it were always the first, patience if I have 2 brackets to assemble, nice casino if I have 50 bolts of which I do not have a series to follow.
a very big problem that I remember plagued the normal 2013 and then partially resolved in 2013x are the features of cutting together, in which first a grouping of the components that are transformed into a body that can be cut, until it works all well, if then you want to replace the components not through the "versioning" but with unrelated components, and the system loses a reference, it becomes very difficult to manage (devading if it loses the sketch).
Catia v6 is at 2016x.
Of course a cad manager who "free" the historian in v5 so.....
the repetition takes place through the patterns.
I'll try and let you know.
Instead, on enovia, contrary to what you said, I found that it keeps the files loaded previously in memory and it's not immediate to reload them. Is there a command to "delete" the enovia cache?
patterns are not "case sensitive", or you have to go looking for them in the 3dparts, and be sure to have assembled the component in the correct position, otherwise the pattern goes in different direction.
enovia keeps the files loaded in the home, but it is not a real workspace, it is more a sort of "chronology", if you load a large set, not fully loaded all the sub-components and in the home see only what you put hand on, in a workspace you would see instead everything.
there should be a command that resets the cache, or the most drastic "catreset"
