chiusura tra due lamiere
  • Thread starter Thread starter corsaro33
corsaro33
Hello, guys.
attached place the file in question.
Today in the office there was a debate on how to create a closing sheet.
at the end we realized that no one really knows how to do this piece,
would be sheet metal banks of a conveyor belt in particular the closure
where you see the void between the vertical and the one at degrees.
it would be interesting to know which method is the best and right.
thanks to hear us. . .
thank you for the answer,
Sorry but I can't open your file,
to clarify,
I would like to know as a rule, the piece of sheet metal must be made, which is to close
the sides of the tape "where you see the void".
we tried with a loft, but the sheet that we go to create remains "svergola".
If you don't see the 888 laura file, I'll try again in jpeg.
I too, very brutally would do two faces, one, the redhead on the same floor of those already made, the other yellow, on a three-point plan on the remaining edges, curved solutions with softening rays can be done, but I do not know if it is worth it.
rather, the shores 9 and 10 for as you drew them, are not developable.....
Thanks tarkus,
the matter was born also because we use inventor from 1 year,
and we thought the program had more automatic functions than "close or fitting"
between two sheets unknown to us.
from what I understood that sheet should be drawn to handle.. .
thanks for availability
:biggrin:mha, what you ask, is rather the function "I read you in thought and then I do as I please."...:biggrin::biggrin:
:biggrin: you know every now and then technology leaves us open... .
Thanks again good day.
Thanks tarkus,
Okay, I got it.
1) as tarkus has written to you (with which I agree also for other replicas) the plates 9-10 cannot develop because, as you can see, the flat model has an overlap of material. . .
2) the closing sheet can be modeled either with planes, axes and so on, or in a much simpler way, using the tool :wink:
3) sponds 5 and 6: leave only the contour and use the flange contour to extrude: time saved both in the construction of the sketch and in the modeling of the profile, all in the sheet environment. or proceed as for the shores 7 and 8: rectangle sketch, face, flange.
(in any case simple and well bound sketches, the more the sketch is complicated, the greater the possibility of cases later)
4) help technology help you: if it seems like a menaced forgive me, but these software, all, are wonderful tools, but to master them you have to bang a lot of your head on
