choice cam
  • Thread starter Thread starter ghiddo75
ghiddo75
I have a problem, in the company where I work currently decided to buy a cam for the management of 5 axes mills for the realization of cutting blades,
cutting of thermoformed parts and resin moulds for sampling of thermoformed parts.
according to my point of view, speaking as a profane, there is no need for a very evolved cam.
Is the company opting for the purchase of the sum3d any one that uses it and indicates whether it is suitable for processing? :rolleyes::confused:
Bye-bye
If you need to do rifilament work, the + fast method is self-learning (if tolerances are "good" )
if you need something + depends on what you have to do.
do models and \o calibri per rifila?
What do you work on?
What's your car?
give me some info that I tell you a little...
It's been a few days since your question, but I try to answer the same.
I use daily sum3d for processing resin molds for thermoforming and for milling aluminum or brass accessories for the footwear industry.
the software does not have a 5-axis processing module, but must be purchased separately (it is called amm and you can read it here http://www.cimsystem.com/prodotto_scheda.php?id=45).
it is however possible to carry out more complex processing using some devices.
in short it is an economic cam but that does its work (with all the limitations deriving from a product of this belt). :wink:
I take advantage of it to greet everyone. I just registered! :biggrin:
thank you for your answers!
the choice arises from the need to create programs for three cutters of the belotti of which 2 to five axes and one to 4, for the cutting of particular thermoformed plastic. the most recent of these millers has a cnc of the osai.
the choice of the cam is linked to the possibility of having a post processor that can destire the axis 5 and 6 regardless of the diversity of the cnc.
Hello, I know for certain that toptron has made various post processors for Belgian machines to 5 or 6 axes with obese controls. you can try to feel the microsystem to see what solution they can give you.
Sorry about the delay but I took 4-5 months to better understand the company where I work currently. This company produces thermoforming products, has three types of 5-axis cutting robots that serve exclusively for cutting operations of contouring and construction holes. programs have always been programmed or through a brace thanks to the help of hand-cut sampling or made in iso language by hand starting from 3d mathematics. Now the need is to find a cad-cam that has the 5-axis contouring function and then is marketed by a company that can interface it with post-processors or studied at d'oc or already incorporated into the cad-cam itself.
according to this deepening secret you what is the best cam based on price/quality for this type of operations?
p.s. I add that sometimes to perform tests we also make simple resin prints.
the question is perhaps a little too generic
Of course the answers will also be sarnno. try to feel beautiful what recommends
I can tell you that with powermill I feel good
5460 much more often steels from moulds and hardened
in a few words I always managed to do everything that customers asked me
other thing Delcam has good service.
Hi, I'd try with roboris eureka maybe it can help you, I know it's already done similar jobs.
