shinobi9
Good evening,
I would need to rotate a load of about 40 kg (a rod) of 90 degrees in about 5 seconds.
I thought I'd use a gearmotor connected to a tree and that tree solidly connect the shaft so that the shaft rotates too. However, having to turn 90 degrees in 5 seconds I have a rotation speed of the shaft equal to 3 rpm.
I think it's very low and I wanted to know what kind of gearbox could be applied. I have considered that for couples in play I would need a couple (at the exit of the reducer) of about 350 nm.
