choice of steel for tree
  • Thread starter Thread starter _Pietro_
I need a k steel resists stresses and twisting moments as it is a tree to work ..the costs do not interest me ..the essential thing is the convenience of processing.mi spiego. .better to take a less hard steel and then I will have to do it in (example 3 past ) instead of a tougher steel with greater breaking load and that I will have to do then 6 or 5 millings .. hope to be explained.just to the processing of steel
the dimensions of the tree do not affect the type of material, its function is.
that of the material that you cannot choose does not understand, but I am not professor therefore.. .
I can suggest you propose some steel and maybe motivate it and then we tell you whether it's okay or not.
you do not want the same metals the prof otherwise I can have the same working cycle of another student.. and by cycle I mean all the calculations behind.. Only to differentiate one project from the other then you have to choose a steel other than those already chosen.. I don't understand it either as a choice xk rightly at the end those are the steels for certain pieces..cmq at this point I cm steels had thought or a c50 or a c35 or some nicrmo.. but I don't know which one I do not know which one.
It doesn't make much sense, 99% of the trees are processed, although they only serve to connect two wheels of a shopping cart.
I am not interested in costs
the essential thing is the convenience of processing. I explain. .better to take a less hard steel and then I will have to do it in (example 3 past ) instead of a harder steel with greater breaking load and that I will have to do then 6 or 5 millings
if you do a working cycle the costs count, otherwise why prefer 3 passes to 5.
I would say that the past is always the same, changes the cutting speed.
better explain the exercise would be useful to do it at the beginning not after milemila post.
If you need to make a working cycle, put any steel.
which then is something already dealt around the forum
