Pablo
Good evening to all,
exists the way, a make-up, a possibility to choose the .sldreg setting file to be applied when we launch the solidworks application? having to work with different settings between them, and having to change often from one to another, turn and turn you forget to launch the correct .sldreg file before starting solid. Does anyone have a problem like mine? How did you resurrect it, if you solved it? thanks to all in advance
