PLT
Let's see if I can explain the dilemma:
I have two under axiemi one a) is a threaded bar with two hinged joint heads on one side and the other b) a tube with an internal butterfly valve, at the butterfly tree that protrudes the tube is docked a brace with a hole that takes with the snode head.
If I wanted to do an animation I should carry the lever with the butterfly that is part of the axieme b at the first level to bind to the hole of the head to snode to... there is no command to make so that the axieme to ie my head to snode is bound to pieces already bound of the axieme b?
