giguz
Who helps me? ? :wink:
Could you upload an image? I don't understand what a flex part is.hello to everyone, I can't perform a circular repetition of an aletta of a impeller (for small turbine) that I underwent the "flex" command. :frown:when performing the repetition does not replay the flexed part!!! !
you have to use the circular sample command and everything works, if you can't, it's because you push the wrong key. .hello to everyone, I can't perform a circular repetition of an aletta of a impeller (for small turbine) that I underwent the "flex" command. :frown:when performing the repetition does not replay the flexed part!!! !
:frown:scusa, I'm new to the forum, I don't know the various screenplays well and I made the mistake of entering the request itself.Could you upload an image? I don't understand what a flex part is.
then I see you have asked the same question on the solidwroks forum, with what cad are you trying to do the job?
