graziano-g
I found and tried this tutorial
http://youtube.com/watch?v=ihm4ulzxei0use the 2015 pro version
I finally managed to:
the sweep with 20 twists (7200 degrees - timeline 7:00 ) of the line on the circumference I could do it only after making the line revolution around the z axis then having generated a surface, at that point I was able to select the line and conclude the procedure, before I was not allowed to select neither line nor circumference.........
despite having placed a point at the end of the line I couldn't generate a passing plan for that point and normal to the path (timeline 7:50 ), the only plan I managed to generate was a passing plan for the point but tangent to the line even if I select the perpendicular plan option to a curve and passing for a point.
then I generated a plan around a edge ( segment ) with angle of 90°
then the rest is ok.
someone with the 2015 version has time and desire to try following the steps of the video and verify that the sequence is feasible?
