climbing stairs
  • Thread starter Thread starter Paulì_zx
Paulì_zx
hi, guys, in this period I'm documenting how to make a stairwell for curvilinear stairs, I was wondering how the custom guides are made according to the stairs, on which to slide the seats or platforms for the transport of people. Are guides commercial products or are they made and designed by mail?
depends on the scales everything can be done if there is clearly need for the costs rise. . .
I don't understand one thing though,
You want to make a lift on your own?
I dispassionately disagree with you seems like a caxxata but there is much more than you see.
You want to buy a lift?
turn around here http://www.vimec.biz/ are very serious and prepared.
Are you planning a lift for a client company?
I should have given you the info you ask here if you have not given them, you should ask them. ..probably they will already have an idea about what to do.
another hypothesis to me unknown?
you should be clearer and above all sincere.
of nothing
hello and thank you for the answer...I tend to point out that the clearer I can be but more sincerely difficult. . That's because I'm not hiding anything but I was just thinking about documenting myself about it to figure out if it's a equipment that I can make myself.:frown:
My intention is to be able to achieve something like this for my home, obviously before I start, I should understand the extent of the product to be realized. not having the most pale idea from where to start, I simply asked for generic information, through which to understand the extent of the problems that I could encounter. Of course, I don't care much about aesthetics or regulations...but I'd like to understand the real functioning of the same.
Anyway, thank you.
If you can give me some advice, I agree.
I'm sorry, but when I don't get suspicious... .
if and just as mental exercise or as a hobby I recommend you first take a look at some site you will notice that there are different solutions from the two "rectangle" guides straight to the round guide with so much of "electronic bottle and gyroscope" from the integrated rack, external, or with dragging with fixed motor. . .
decide by looking at the existing solutions which and the one that is best suited to you then if you want to talk about it I am not so much but a hand I can give you.
to answer your initial question normally use as standard guides their non-commercial standards especially for reasons of cost, in particular cases they carry out ad oc routes.
hi,good hobby
p.s.
But keep in mind that if you were a real need it is absolutely unthinkable to build it on your own both because as I told you there are more than it seems to be for economic reasons in fact on similar products in case of necessity there are "flowers" of concessions of provinces common regions etc.often are the same sellers that can facilitate you the practices.
Anyway, thank you.
I know people who, in the past years, committed months of design and testing in the workshop, also spent good money and I don't know if he managed to get anything.
I saw the prototypes, they always had a problem.
ps.: meanwhile they have failed.
Bye.
the only one is to rely on a designer trusted with specific expertise in product design is with a good experience in industrialization of the same especially with regard to movement (mechanical and electronic)... I repeat to myself for not self-quota me there is much more than it seems.
