closed multiline
jim78b
I find myself drawing sheets and so I often have to make rectangles, not to turn them into polylinea and then close them I find it convenient to use multilinea but then I always have to close the ends of it, there is no way to do it quickly? or do closed multilines?
Why is the rectangle command not good, which is in the form of already closed polylinea? which also has the width option?
even if I didn't understand what you need to have a multiline that normally serves to track multiple parallel lines.
Sorry returning to the ultilinea, you ragine the rectangle but I would need you to leave down with thickness type 8-10 mm and then rotateable, without having to make lines of construction before.. .
excuse me if I allow myself, but before posting read again a moment what you wrote because typing errors and lack of punctuation create difficulty reading and maybe even misunderstanding.
returning to the topic if closing the multiline is not comfortable do a rectangle and then do a x-thick offset. I don't think there's... probably there are some lisp, look in the section lisp per autocad
