xLOGANx
Hi, guys.
I need to ask you a question which I hope you can answer. I happened to reveal a cloud of points of a component to be used for teaching purposes (it is a parallelepipedo). When I perform scans, with the software supplied to the 3d scanner, I have a way to place the piece on the origin of the reference system. This means that regardless of the reverse software used, when I open the cloud I will see it correctly set in space 3d.
now that I have received a cloud already beautiful and ready, it came out I am trouble. I ask you: in geomagic, is there a possibility to fix the cloud compared to the software reference system? in practice, is it possible to orient the cloud of points so that the 3 fundamental planes coincide with 3 of the 6 faces of the cloud?
I ask you this because in rapidform there is the possibility to "re-orient" the cloud but not as a cloud, but as a native file of rapidform.
thanks:finger:
thanks:finger:
