piccio__87
Hello!
problem!
constraint between 2 holes with coincidence-->
1)axis with axis (I remain free movement along the axis between the two holes)
2)point of the hole (center) and axis of the other hole (I remain free the "spheroidal" movement coincides with the axis but in coincidence of the hole point without possibility of translating it as in the first case)
If you want to give a point-translation tolerance on the other hole axis so that you can translate it???????? is there a command that escapes me?
Oh, my God, I hope I've explained... :
Now I have to run away, tomorrow I have pictures to explain better if you don't understand.. .
problem!
