comaulib per autocade 2004
m.engineering
Hello everyone,
Does anyone know where it is possible to download or send the fantastic utilities for autocad comaulib? I own a very old version (for autocad r14) that with 2004 has some problem.
Thank you all.
I would like to install the comaulibs attached by 'stefanobruno' in his message of 10-11-09, I downloaded them on my pc but then I do not know how to proceed (work with autocad 2004);
Can anyone tell me the steps?
Can anyone tell me the steps? . . .
What can't you do?
Did you do the setup?
I opened the zipped file, but when I do 2 clicks on setup.exe tells me:
<<cannot actions="" checkout="" contains="" filename="" folder="" information.="" install="" install:="" instead.="" or="" program="" setup="" use="">></cannot>
I started the installation, without bringing it to completion, and normally starts.
What operating system do you have?
windows xp
I'm definitely wasting your time, thank you.
I also have the xp. But the message seems strange, sure that you have not inadvertently deleted some files? from that writing seems like the setup file doesn't find anything. . .
ps: the time you spend here on the forum is never lost time! :wink: you always learn so much...
but did you unzip it in a folder before launching the setup.exe?
after you did and that the setup generated the "comaulib" folder... " you have to open autocad, go to options and add the same folder to the file search path.
close acad and at the reopening you should see a window that asks you where you want comaulib to create Temp folders and "something else:biggrin: ".
this is the signal that confirms the correct installation.
that comaulib works well until rel. 2007.
for later versions, until 2010, there is an updated release.
I try to tell you what I did:
-Saved the zipped file in c:/programs
-extract the zipped folder and saved in c:/programs
- so the comaulib 2002 folder is generated
-open autocad, options, added to <percorso di="" file="" ricerca="" supporto=""> the comaulib folder 2002
- autocad shutdown
- the reopening however has not changed/it has not asked anything
Thank you.</percorso>
- autocad shutdown
from the procedure you have listed but one thing is missing: the launch of the setup.exe file
I finally installed the comaulib 2000 that seem to work on autocad 2004.
summarize the procedure I have done:
-Saved the comaulib 2000 folder in c:/programs
-started 'setup' within the comaulib 2000 folder
-the system thus generated the comau lib folder in c:/programs
-open autocad, tools, options, added to <percorso di="" file="" ricerca="" supporto=""> the comau lib folder
- autocad shutdown
-The opening window of the comau lib asks for the path where to save the cfg, temp, trasl files
-indicated c:/programs/comau lib
- placed on the toolbar the windows of interest
-verified in displays, toolbars the presence of comau lib
I also tried to install as above the 2002 comaulibs, but without success (at reopening autocad are not displayed).
for now I'm satisfied.
thanks to plannerroad !!!
(without your suggestions I would not have succeeded)</percorso>
