blubossa
How to create a .fas file?
so the procedure is the same even if you try to compile 1 only .fas file? ?the easiest way is with vlisp, creating a new application you find, among others, .fas and .vlx
I tried and works Perfectly acaddoc.fas is loaded normally.fas are compiled lisp (for protection), I still do not find the existence of "utility" able to stick to our nose.
I have not deepened though:.fas are compiled lisp (for protection), I still do not find the existence of "utility" able to stick to our nose.
