[comecareper] Punzonatura su tubo
  • Thread starter Thread starter bazzy
I think of 2 roads: one making the sheetmetal tube and then making the buttering on the flat sheet (with the folds), or in part with the surfaces.
You can do it with loft protrusion.
the stages are:
- projection of a circle on the surface of the pipe (represents the base of the punching)
- 1-point sketch (presence the tip of the punching)
- creation of a loft protrusion with base the projected circle and somity the point of the sketch. in the options set to pass parallel to the point.(publishing in the table variables point parallelism)
- radiate the base of the protrusion
- Thick the pipe.
allego example
View attachment Tubo esempio.zip
you can also do it with the protrusion of loft.cut
If not, I was thinking now:
(since I momentarily made a hole as reference)
-creus a cylinder from the plane to the circus ext
- I ran all the inside
-I'll pick the tip on the cylinder
-minimum surface thickness=spedssore tube...
destroyed but maybe it works. . .
First I try the surface away! :wink:
In my opinion you may have problems mating surfaces once you create the thickness.
If I had to approach it with the surfaces I would follow another path.
the stages are:
- Cut.
...proven, punching is good, now the problem is that I can't thicken the surface.
even in your example is not often the internal part.
for now I solve with a "decorative" excavation, I tried to make an insert with offset, the silhouette of the surface does not seem editable (I can not cut it on the axis of rotation of the cut)
I think another system is:
- draw a round protusion of the diameter of the tube,
- draw the two punches on the outer part (or with revolution protusion or with a flat protution and then go to remodel with bevels and fittings )
- use the thin walls command to give thickness to our tube
...for now I'm satisfied with the surface+loft+I'm "decorative". If I could turn it off, it would be perfect.
next time I use your method instead, for today I seem to have lost time enough!!! :wink:
