command animaperc
  • Thread starter Thread starter mariozz
mariozz
I have a didactic project that weighs about 60 mb, and the processing of the same begins to become problematic as also the response times of autocad are long.
Now, I tried to make an animation with animaperc but there is no end to processing.
I also tried to do the same animation with other software (pcon.planner) but also very long timing.
How could I streamline the project?
Yes. I followed a tutorial but it doesn't change much. .
What does the tutorial have to do with file cleaning?
Did you use the purge command?
the design comes from other cad?
have you used blocks and/or groups?
how you set the rim resolution (system variable viewres )?
you know nothing about this file, giving a solution is almost impossible
beh guarda...ho win10 e sto usando solo chrome.
View attachment 615144 gb of rams are just enough for the os...say that autocad response times are long? I'd be surprised, frankly!
sisi, then it's all in the norm... I heard about making farm... Could it be useful for me? specific that for now, autocad I am using it for educational and not professional purposes.
ho little ram.
very little. Moreover autocad becomes very heavy when the files are great.
But even with four gigs, you should be able to do it.
premitting that I have never done animations with autocad, the delay happens when creating the video file or even delays even video in the sense that you do not visualize the movement to video.
because video files are nothing but a series of frames (rendered or not) that are then assembled by autocad in a unique file (wmv, avi, mp4 etc.). It is clear that at this point the process is by force of long things.
longer is the path and more frames will be created. much depends also on the set frame rate.
test giving low values to frame rate and number of frames.
anyway, animation, i.e. creating a video, is a process that needs time
