command line
  • Thread starter Thread starter stevio
stevio
first of all I want to thank you for this usefulssmo forum!
Where the hell did she go? One day there is and the other is not!
then the command line that breaks the boxes near the cursor... How does it take off?
Can you help me? I hope to be clear.
autocad mech 2010
I...
as regards questions: ctrl+9 to make the command line appear and what you mean on the side of the cursor should be the dynamic input... remove it with the caselline (a crucifix with a white rectangle) in the bottom left (near the coordinates).
autocad mech 2010
listen to stevio,
to remedy this puzzle that I use regularly, you have to go on "assist" which is at the bottom of the drop down menu.
assist opens all the customization files of the program. up there are all the menus in line. look, I think, "design" or something.
You can move the commands from the cursor to the bottom row below the display.
I hope I didn't sing. If I sing, I'm sorry.
Gcf
Thank you 1000! Perfect!
Sorry, giga. First of all, it's nice to meet you and I'm sorry to interfere.
I recommended that you enter assist and search for "design". apart from this, I use mech2008 ita and about a month ago I found myself no longer having a lot of commands like "toggle shading" for the 3d, "rotate 3d" which however I always had to type it because its icon rotated on the floor. so many other commands are gone, he replies: unknow this command press f1 what did I do?
I'll send you a big ciuingham like this.
hello, gcf (cuor of rabbit).
listen to stevio,
Gcf
Didn't you notice that maybe it's late?
She solved a couple of months ago.
Marco:smile:
