command problems size with version 2022
  • Thread starter Thread starter fabius69
fabius69
Hello, everyone.
on the autocad version 2022 the command cuts on a drawing with many objects, if you do not immediately use the "t" option, to select a cutting object, it stops. What do you think is a bug?
Thank you. fabio
locks because the command cuts or extends with immediate sending size or extends up to the first available entity and must process all the design; It's not a bug.
as Massivonweizen certainly says is due to the processing time of autocad.
It is however possible to return to the old way of working by setting the cutting mode.
from the sequence: ta-o-s (cut, mode, standard).
from now on the command cuts back to the old way.
with ta-o-r bring it back quickly.
in the quick mode also counts the frame (i.e. what you see at video). according to the frame, autocad, understands what must and should not cut. and perhaps if you remove from the picture big parts that are not interested then the times should be reduced.
Also note that the quick size allows to delete additional parts that have remained out of the cut without having to switch from the delete command.
