command size/elimina
  • Thread starter Thread starter IN.TEC
IN.TEC
Good morning, everyone!
I wanted to ask you for help.
I also ask that I did not do any research on old discussions because I don't even know what to look for. . .
My problem is to remember a command I used years ago. I found it in the express tool bar and had the size function and delete it together.
I remember that with this command, once you track a line/poliline/retangle/circle/etc etc, you could cut and delete everything that was on the right or left (or inside/outside in case of closed geometries) only by selecting the side of which you "wanted to clean everything".
sincerely now on my mechanical (vers 2013) I can't find the command or remember the name.
Can you help me?
thanks in advance
Good week
Good job
Faithful
