command "undo" its solid edge
  • Thread starter Thread starter Tequila
Tequila
I would like to know how many of you work the "undo" command said also cancels or simply ctrl+z.
it never worked out or hits only in environments where it wants.
I'm on a set, I select a particular and replace it with another,
I realize I have selected the wrong piece, I press cancel (ctrl+z) or
also the command at the top left on the st but does nothing, become gray.
even on dfts if I remove a view and I realize I've done stupidity, if I do ctrl+z it doesn't do anything to me.
but if you can't cancel or go back a few steps? ? ?
the problem I carry it back from v17 and on the st they had assured me that it had been settled.
I wanted to know if you have the same problem, or if I'm the loser.
I also noticed that for certain commands the grape does not work, it almost seems that you do not want to remember that operation. I don't know if it's because the management of complex operations would weigh too much... but it's weird.
No, no heavy operation, it just doesn't work.
the commands for which it is not expected the grapes ask confirmation before being executed. I don't know how to answer that.
Look lately I don't know how he thinks solid edge. I made some changes this morning to a set, I changed a seeger and a seal ring, putting them bigger.
I mistakenly replaced the seeger with the seal ring (I do not use the standard parts, we have details with internal coding), failed the relationships rightly I find myself 2 connecting rings, I do not press anything or save nothing, I do "nail" by button but it is gray and therefore I have to go out without saving (or reestablish the piece with the correct one).
Premute that on solid edge/general options an increase in part and assembly is set to 10
Same as the draft. I erased a quoted view, I realized I did the stupidity that was not what I had to cancel, but nothing to do, the "nothing" are not there, eh si che anche qua sono set a 10.
By the way, I have now made a test on an assembly and replacing a particular with another does not ask me for any confirmation.
