compatibility cocreate to wf2
  • Thread starter Thread starter Dancan
Dancan
someone knows if cocreated native files can be imported directly into pro|e wf2.0 , recreating a stunt model tree of the features ,modifcare feature ..insomma manipulate the model as if it was created to pro|e .
I think in cocreate the features don't even exist when you're still in cocreate. . . .
you can do it exporting from modeling in granite format (*.g) so pro-e releases the features. you can do one part at a time you can't export groups
but now modeling turns on granite? historically used acis, didn't he? Or do I remember badly?
and now with granite it turns seriously:-)
By the way, a question and probably the answer is yes: in me10 is it possible to import dwg and dxf formats?
If you in a couple of weeks I will need to save in me 10 a dozen pro/e tables.
If I carry out in one of these formats, who would do me courtesy?
ambetre, but dxf better.
I'm sorry, but I don't understand.
-What is the best way to transfer cocreate native models, x be able to put me in a position to work as best as possible with pro|e (wf2.0)? ?
Thanks
..ehm ...if it's like with pro-and then you'll want to say it's really planting....:biggrin:
Thanks
export from modeling in granite format (*.g), you must have the 16.50 though.
What would be the advantages of exporting in the format you say (*.g) rather than in iges or step ? ?
You could ask someone in the forum to post a file in granite format and then upload it with your pro/e, so you realize yourself.
That's what you do. exported to granite 3 (for wf2 and sucessive)
I said that it only works for the parts but instead I found that it works with the assemblies. simply export to granite.zip :smile:
Try and make me know.
with wf4 tells me that the files were created with a more recent version of pro/e, so they are empty.
