compatibility windows 7 64bit and autocad
ok thank you, I read and seen in the second link that is a little question of conflicts, in the past I had had the same problem on xp with the antivirus panda and I had to uncheck the behavioral analysis and at that point it worked.
Now I have the nod32 6.0 obviously as first thing or thought about that but I don't know if there is any option to poke.
regarding the links you gave me I can't install the service pack1, it gives me error 114, while I wanted to ask you what the third file is before installing it.
the link is drawn from the discussion of the link in the middle
is always an autodesk file and should serve to delete gedit error Unfortunately all these packs have been developed up to windows xp so it is possible that the installation does not work.
I wanted to run autocad 14 (not 2014), had managed it because there was an application that works great in that version for certain things, and even if that application has been updated until now has not the same precision as that of then, had autocad 14 I managed to make it work the application while I clear the mountains and therefore for that it remained only xpmode
so as you see for some you need dedicated virtual machines or a series of pcs in the network where the files resulting from old pcs assemble them in the modern pc
What I don't understand is that acad 2002 turns well and all the functions go, randomly exit that error does not have a precise rule, could it conflict with something?
Is there a way to understand how these mistakes are generated?
