compilation dwg cards with pdm properties
  • Thread starter Thread starter Sp4rk0
Sp4rk0
Good morning to all,
I use solidworks with pdm, of course the boards automatically fill in with the right attributes of the pdm, I wanted to know if it is possible to have the same compilation using dwg files, creating an appropriate folder with the properties to fill out.
I did some tests by putting the same strings I have in solid models for example [$PRPSHEET:{Titolo}], even on the dwg chart, but don't fill them, I don't know if I have to make a cartilage with attributes or if I have to write different strings.
if you can have the same compilation using dwg files
It explains better.
you enter a dwg in the drawing environment and would you like the data to be compiled?
No, you have to fill out the cartilage in the pdm environment, however I have solved, it is a procedure that you have to do as administrator of the pdm system, I did the assistance.
