mariuss.r
first suggestion, based on the images you posted.you well consider that it is as a unit measuring 10 modules, I can get up to 64 modules then 640 on two extruded bifacial profiles.... total 640x4 = 2560 modules. solidworks doesn't bother me, snaps a bit but keeps banging, considering that it also has all the other components
in the second image there are the properties of the object, from which it is shown that you managed to combine the surfaces in a single closed polysurface (a solid therefore).
select the object ... press f3, to view the properties, and remove the check mark under the heading "isocurve monster". This will make the object much lighter.
see image attached
