MassiVonWeizen
point 1 in the cut of the part you must create and fill the num part property; this for files already created; then open the part file, expand the cut list,, right-click on each folder and in the table that appears enter the property (must be identical to that of the distinct) and its description. if you have too many folders to fill in right-click on the soldering symbol after the origin) and do the same procedure, this should automatically add the property to all folders present in the cut-off
if you do the profile file properties you will already have the voice created automatically when using the structural profile in the part; then open the profile, menu file>properties and create the property
