snake779
Good morning to all,
as from title, I would need to know if it is possible in a set with 2 configurations, use the "substitute component" function but only in the active configuration. I'll explain. I have a set with a and b configuration in the configuration to I have a "z" tree with above the "y" component. in the b configuration I always have the same "z" tree but I want to use the component replacement function, going to replace "y" with "x". since components are similar to replacement but does, but unfortunately it extends it to all 2 configurations, which I do not want. I tried to turn a bit to see if this function allows to choose " replace only in this configuration" but I found nothing.. .
thanks in advance
p.s. solidworks 2018 sp3
thanks in advance
