component table - file name *varia*
  • Thread starter Thread starter bebeto
bebeto
Hello everyone,
I have a problem that I can't fix when I create the component table.
I have two tubes with the same size inserted from the contained center, to one I have made some work and obviously have a different file name.
When I create the component table, inventor me group them into a single line and in the "filename" column writes to me "*vary*".
I need these two lements to be separated, how can I do that?
the version of inventor is 2010.
the separate default components group the items according to the number part, so it changes the latter to one or more tubes. now it tells you varies because both have the same number part but with different file name.
or go in union setting rows and remove the tick on "habilita union rows on n° part"
Thank you, I searched for such a command but without finding it, it was also 4 at night:biggrin: and hoping that there is on inventor 2010.
the number part I can't touch it for the separate components.
you have renamed a tube without carrying out the copy save by name.
try to open the second tube, the one you changed the name, enters the iproperties, verify that the name part has been modified, you also have the name in the browser should have remained as the native file, it also changes that.
the name part I can not change it otherwise I would lose the properties.
the right solution is the one indicated by peppe in my case.
