composite materials walls - folding inserts/ end
  • Thread starter Thread starter cadrev
cadrev
Good morning to all,
I'm running into a problem with the material compute. I need to have the actual insulation sqm under control but I noticed something strange. on the walls that "host" windows, the insulation layer folds towards the wall as at the end of the wall itself.
the data returned from the computation however does not take into account the folds, in the presence of a window/door or at the ends of the wall.
is it possible to ask revit to take account of it? ? ?
I add that in my case a useless data is returned. I would prefer the vacuum for full, so I also ask you how possibly it is possible to exclude a window/door from the calculation of materials.
uses phases of work and created a phase in which doors and windows are demolished or unrealized
:eek: I hoped there was an automatism that avoided the stages, however better than nothing.
As far as the first thing I asked for is impossible at present right?
At this point, however, I have another problem. inserting the window into a later phase, the insulation in the compute is calculated blank pp, but it still turns around as if the window is still present.:confused:
How do I avoid this graphic error?
Thank you for your help! :finger:
