dadefault
hello to all
I find myself having to compute the doors inserted in the continuous facades that in turn must be computed
the problem is that continuous facades do not work as normal walls: If I replace the glazed panel with one of the doors I buy both the door panel and the facade continues, thus creating a double compute, because it does not perform the volumetric subtraction that you have with the door placed in the wall.
can I have the door-mirror cut effect with the continuous door-panel system that instead replaces and doubles the computs?
