lukke
hi to everyone, I looked at the forum and the solidworks guide before posting this discussion, but I couldn't find anything that could help me solve my problem. I'm trying to explain. I interfaced solidworks with a pdm working via plug-in. from the pdm I send a parameter to solidworks that I inserted in the equations. in the file properties I define a new property to which I assign as value the parameter just defined. the question is: is there a syntax to say that if that parameter is 0, the value of the property must be a, otherwise it must be the value of the parameter? I tried with some if, if etc... But he doesn't like it much and I can't even figure out whether it's possible or not. Is there someone who can give me a tip? Thank you very much
