configurations
  • Thread starter Thread starter cadistaME
cadistaME
does it happen to you that by activating a saved configuration, the model rotates as decided but does not respect the rotation axis? arrives correctly in the new point, however, following a trajectory of its own. according to you can do something or do you need to buy the assembly module?
thanks and good work to all.
I believe that to pass an object from the standar position to that of the configuration, osd let him walk the shortest path, however it does not follow the movements you made to place it in that position.
This does not even happen with the classic relationships of advassembly, the only way, that I know, to see the objects move from one position to another as you wish is the animation command, always of adv assembly, which serves to create movements with small steps.
Here is a small example:http://www.youtube.com/watch?v=zfxmi9hqluu
As much as you wrote to me is of great help, I avoid losing time with the software I have.
Is there something free to do with simulations? type cam movement, anthropomorphic movement, etc.
hi, the tool you need is the advanced license for modeling, which among other things also has the constraints of parts and assemblies and allows you to do simulations.
Here is an example here:http://www.youtube.com/watch?v=ycuoapbe3naSorry if I place it for the second time, but it's too nice
