configure dotted lines
  • Thread starter Thread starter GianniM
GianniM
then come back with my – big niubbo problems.
I made the table of a part, some lines are continuous, the hidden ones are dotted, as it is right.
the problem is that the dotted lines have an excessive restraint length.
there are other restraining styles such as “ x2” and “ x5 movie”, but these are even larger.
if I look at the properties of the single lines the function “scale” is disabled. I don't understand why.
However I would like to change the style properties, so that all lines are updated automatically, but I don't understand how to do it?
Can I help you? Thanks, you're always mythical!
ciauz
the style of line is defined according to the iso norm. However in the layer section you can edit the associated line type, for example I find a "hidden .5x".
to the limit you can edit the file c:\users\public\documents\autodesk\inventor 2014\compatibility\support\inviso.lin to create a custom line type.
I did some evidence, you're right.
I'll try to study on it, thank you, for the answer. Maybe I was wrong using scales of depiction investigated.
