Stefal639
hi, my name is stefano, I am aquilano and study here from me mechanical engineering... already for years "bazzicavo" with these programs in a very jumpy way, but only to acquire small components of cars or motorcycles, that then we made to realize to the cnc, but it was always and only of simple objects, like the plates to distance the brake calipers, of the spacers for the quads or things of the race...
as an end-of-course examination we must report the complete reconstruction of each detail and the assembly of a mechanical assembly...I chose for the examination to bring the mechanics of an electric rifle to compressed air...the parts dismantled you can see in photo
here are my first difficulties. ..I am not at all able to realize the big gear in the bottom (the three big ones you see, but also the pinion connected to the motor). ..as the exam is in January and the proffs still explain how to make the quarries or simple extrusions, I wanted to anticipate the work;-)
my main problem is the realization of the conical part...I don't know how and where to start...I tried to draw a profile of the "piena" wheel, writing the equation of the plane perpendicular to the tilt of the wheel and making a tooth sketch I got making a quarry a single tooth, but unfortunately it is not for nothing similar to the original...for the classical dense wheels with straight teeth I did not find any difficulty because before
to conclude my presentation: My dream is to work in a car prototype company.. .for years I design a prototype with tubular frame, including suspensions and other...because thanks to this wonderful faculty I learn how to "progetta" every now and then I take back the drawings and I always modify them + to get "perfect"... only a few months ago I discovered that practically my design exists almost identical in reality... his name is ariel atom;-) I have to say that the disappointment there was a bit,
cmq to conclude: Nice to meet you all. I'm sure I'll be fine.
ps: here is a photo of the gear and the point where I am.
for the most attentive: yes, I did wrong that part under the toothed wheel + high... I did it on the contrary.
here are my first difficulties. ..I am not at all able to realize the big gear in the bottom (the three big ones you see, but also the pinion connected to the motor). ..as the exam is in January and the proffs still explain how to make the quarries or simple extrusions, I wanted to anticipate the work;-)my main problem is the realization of the conical part...I don't know how and where to start...I tried to draw a profile of the "piena" wheel, writing the equation of the plane perpendicular to the tilt of the wheel and making a tooth sketch I got making a quarry a single tooth, but unfortunately it is not for nothing similar to the original...for the classical dense wheels with straight teeth I did not find any difficulty because before
