conical thread bspt
  • Thread starter Thread starter murdok
murdok
Good morning to all,
as from title I need to create a conical thread with catia type bspt, can you help me?
I remember nothing more about bspt, but I assume that with the propeller and sweep you should succeed:
in generative shape design:
create filet axis and profile start point
menu/insert/wireframe/elica and select axis and starting point, inserting step, height, orientation and angle of tilt of the thread
then insert a normal plan to the curve ( propeller)
create a sketch with the tooth profile
menu/insert/superfici/sweep/profile with the direction of extraction and selection the profile the guide curve and the direction (long the axis)
if you cannot post the bstp table you have to use
thanks for the answer, but my problem is not drawing it, I would like to import parameters from a txt file or xls. maybe I mis expressed myself in the request, in the hole command there is a possibility to import parameters for non-standard threads
create a xls or txt fillet table until version 22 after version 22 a htlm table should be created and inserted into different folders depending on the caty version. if you need the patname let me know what version of catia you use hello
