EMANUELE78
I would like to know if you can connect an access file (or excel),
to a block using data fields within block attributes.
However, the available data fields are blocked and I cannot add a "custom" data field to which the database is associated.
What I would like would be to get a distinct base starting from a mechanical design.
an alternative would be using "linkdb" but it seemed a bit complex. . .
