connected lines considered as the only entity in moving
  • Thread starter Thread starter MaiMollare
MaiMollare
Good day to all
are a proengineer user who due to force majeure is forced to return after years to the good old autocad.
I found a very annoying problem that I can't fix:
If for example I prolong one line on another perpendicularly, and then I try to move it, autocad considers them as a unique entity and moves them together as if it were a block.
this problem matches it for each length line circle etc.
I also tried to use the grip but same speech.
Is there any secluded variable I don't remember anymore?
thanks for your help
you're right I checked, it was updated, and it went from autocad 2009 to autocad mechanical 2011
